ALERT - Linus Tech Tips, Tech Quickie, Tech Linked Youtube Channels Hacked ×
Bluescreen of death help
 Share
I keep getting the bluescreen of death. All it says are WHEA_INCORRECTABLE_ERROR. I narrowed that down to mean hardware failure but I still don't know what hardware is failing. It only happens when the computer is under load (Playing world of warcraft and other games) Here are my hardware specs and some Windows error logs. Yes I know this is ancient technology and should be in a E-Waste Bin but this is my only rig for right now while I save for a new one.
Its not thermal related. I've never seen the CPU get above 63°C or the gpu above like 70°C I think something is dying but I cannot figure out what
Many Thanks,
-Ninjasupahsquid
Well yes its likely one of your bits of hardware is the issue, it could be anything, the only real chance of finding the culprit is to swap parts and retest, run memtest see if it throws up any memory issues, disconect any extra drives other than windows drive and test, try one stick of ram etc, really need spare gpu to test or test yours in another machine
yes its old and cannot be expected to last forever, but all you can do is try and narrow it down
1 hour ago, Ninjasupahsquid said:
Here's a HWINFO log file if you need more LOG FILE.HTM
That motherboard has a newer bios available.
https://www.gigabyte.com/Motherboard/GA-78LMT-S2P-rev-5x/support#support-dl-bios
Also, check your drivers with IObit Driver booster.
Here's the latest chipset driver:
https://www.amd.com/en/support/chipsets/amd-7-series-chipsets/780g
Check the RAM with Memtest86+.
WhoCrashed is also a tool which might help.
  • Main PC: AMD Ryzen 9 5900X - EK AIO 360 D-RGB - Arctic Cooling MX-4 - Asus Prime X570-P - 4x8GB DDR4 3200 HyperX Fury CL16 - Sapphire Pulse Radeon  RX 5700XT - 1TB Kingston Fury Renegade - 1TB ADATA SX 6000pro  - 512GB ADATA SU800 - 1TB Seagate Momentus 5400rpm 2.5" - SAMA Armor Gold 750W  - custom black ATX and EPS cables - Fractal Design Define R5 Blackout - Windows 11 x64 2022 - 3 Arctic Cooling P14 PWM PST - 2 Arctic Cooling P12 PWM PST
  • Peripherals: LG 32GK650F - Philips 226VL - Logitech G Pro X Superlight - White Shark Spartan X (TKL) - EndGame Gear MPC890 - Genius HF 1250B - Asus Xonar U5 - Sennheiser HD 560s - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Laptop: Acer E5–575G-386R 15.6" 1080p (i3 6100U + 2x4GB DDR4 + GeForce 940MX + 256GB nVME) Win 10 Pro x64 22H1 - Logitech G305 + AAA Lithium battery
  • Networking: Asus RT-N18U - SpeedPort Plus - 35/7 Mbps vDSL - TP-Link TL-WA850RE - TP-Link 5-port 1Gbps switch
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS - Samsung Galaxy Tab A8 10.1" - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color
  • Streaming/Server/Storage PC: AMD Ryzen 5 3600 - LC-Power LC-CC-120 - MSI B450 Tomahawk Max - 2x4GB ADATA 2666 DDR4 - 120GB Kingston V300 - Toshiba DT01ACA100 1TB - Toshiba DT01ACA200 2TB - 2x WD Green 2TB - Sapphire Pulse AMD Radeon R9 380X 4GB - 550W EVGA G3 SuperNova - Chieftec Giga DF-01B - Logitech G710+ - Roccat Kone Pure Military Desert strike - Logitech S-220
 Share
