Case ideas
Go to solution Solved by SorryBella,
3 hours ago, astn22 said:
I'm looking for a case and i've narrowed it down to two options:
1. Fractal Design Pop Mini Air MicroATX Mid Tower Case
2. BitFenix Nova Mesh SE ATX Mid Tower Case
Either or. Find good deals on one of them and get the lowest price, theyll perform similarly. Ease of build though definitely goes to fractal long experience with cable management.
Budget (including currency): <90ish usd
Country: USA
Games, programs or workloads that it will be used for: n/a
I'm looking for any size case that is all white with rgb.
I love the look of the Fractal design case, but people where saying you might need to buy a 10$ cable and I have no idea what that's for or where to buy it. The BitFenix is a bit cheaper and looks almost as good.
If y'all have any experience or knowledge about these, or just opinions, let me know.
https://linustechtips.com/topic/1485535-case-ideas/
go with the Fractal Design Pop Mini Air MicroATX Mid Tower Case. It looks like it has better cable management and its cheaper.
My First PC
CPU: Ryzen 5 5600x
Cooler: Asus TUF Gaming LC240
Motherboard: Asus ROG Strix B550-f gaming
RAM: 4x8 GB Corsair Vengeance RS (3200 MHz, CL16)
Storage: 1tb Samsung 980 Pro
Graphics Card: Asus Dual RTX 2060 OC
Case: Deepcool Matrexx 50
Power Supply: Corsair RM650x
Headset: Razer Blackshark V2
Keyboard: Corsair K70 Pro Mini (Speed Silver switches)
Mouse: Razer Viper Mini
Only changes I have made is I sold the 2060 for $235 AUD and bought a Powercolor Red Devil 6700 XT for $400 second hand (it was barely used, think I scored a deal on Ebay with that).
I love Photography (Using a Canon 60D)
Love F1, my favourite team is Ferrari and my favourite driver is Leclerc
https://linustechtips.com/topic/1485535-case-ideas/#findComment-15780688
A front panel USB-C port is optional on Pop cases. That is the cable mentioned.
https://linustechtips.com/topic/1485535-case-ideas/#findComment-15780705
Press quote to get a response from someone! | Check people's edited posts! | Be specific! | Trans Rights
https://linustechtips.com/topic/1485535-case-ideas/#findComment-15780753
