I turn on my pc about 10 seconds after boot the fans turn off for my gpu. I have an msi 3060 and it’s brand new. The rest of the pc is fine but can anyone give a suggestion? I’ve taken it out and waited till it cooled and then it still did the same thing. When I start gaming they do not turn back on. I can go into the bios, and they work. When my pc gets on the login screen where I enter my password it just shuts the fans down. I play games like fortnite, i do not overclock but it would be great if i knew that my gpu wouldn't get fried. If someone could tell me to change something or do something physically to it it would be great!
https://linustechtips.com/topic/1485072-gpu-fans-dont-work/
Open MSI Afterburner and manually set the fan speeds to verify they do work. This is feature on modern GPUs where they'll turn off the fan until it needs cooling. But of course if you want, you can manually override this. My 6650XT has its fans turned off as I'm typing this.
Intel® Core™ i7-12700 | GIGABYTE B660 AORUS MASTER DDR4 | Gigabyte Radeon™ RX 6650 XT Gaming OC | 32GB Corsair Vengeance® RGB Pro SL DDR4 | Samsung 990 Pro 1TB | WD Green 1.5TB | Windows 11 Pro | NZXT H510 Flow White
Sony MDR-V250 | GNT-500 | Logitech G610 Orion Brown | Logitech G402 | Samsung C27JG5 | ASUS ProArt PA238QR
iPhone 12 Mini (iOS 18.3) | iPhone 15 (iOS 18.3.1) | KZ AZ09 Pro x KZ ZSN Pro X | Sennheiser HD450bt
Intel® Core™ i7-1265U | Kioxia KBG50ZNV512G | 16GB DDR4 | Windows 11 Enterprise | HP EliteBook 650 G9
Intel® Core™ i5-8520U | WD Blue M.2 250GB | 1TB Seagate FireCuda | 16GB DDR4 | Windows 11 Home | ASUS Vivobook 15
Intel® Core™ i7-3520M | GT 630M | 16 GB Corsair Vengeance® DDR3 |
Samsung 850 EVO 250GB | macOS Catalina | Lenovo IdeaPad P580
https://linustechtips.com/topic/1485072-gpu-fans-dont-work/#findComment-15777318
this is normal, at startup the fans do a "self test" then shut off until needed.
u can check that while playing a game with msi afterburner overlay or simply listen to the pc ,the gpu fans should be pretty audible once they kick in.
typically manufacturers set the fans to turn on around 60C btw
-Scott Manley, 2021
https://linustechtips.com/topic/1485072-gpu-fans-dont-work/#findComment-15777323
