Need help with cmd popups
Solved by Budget DIY,
I would just try putting in an USB stick with a windows installer on it. The first real option in the "installation process" should be repair windows. You could also try to do a "windows restore", where you pick a restore point before these issues started. There are MANY tutorials with all the screenshots if you google for it. But I'm not sure if the windows restore works. Registry sounds really messed up.
Mind you, not an expert or anything.
