Graphics Card power
By
superdupahorn
in Graphics Cards
in Graphics Cards
Solved by nj4ck,
AFAIK, the 12V cables all connect to a single 12V rail on that PSU, so you'll be fine with running the GPU off of one cable. My guess is also that they wouldn't make a cable with 2 connectors on one end if you're only allowed to use one. I run my R9 290 off a single cable as well.
YoungBlade ·
Posted in CPUs, Motherboards, and Memory9 -
4
derekchan ·
Posted in New Builds and Planning8 -
1
2
6
5
7
kerriya ·
Posted in Cases and Mods14
play_circle_filled
Latest From ShortCircuit:
