USB to Micro SD Possible??
Go to solution Solved by CyberneticTitan,
There are microSD to SD card adapters. For example there is this: https://www.pcboard.ca/sd-to-micro-sd-adapter
and this: https://www.aliexpress.com/item/1005003590150308.html
If you do find a microSD to USB adapter, I would be weary if the adapter was not flexible like the one above. I have a hard time imagining the microSD card slot being able to support a cantilever USB thumb drive.
So I've been 3D printing for awhile and I just got a new printer a Sovol SV06 but it uses micro SD and not a standard SD card. I hate using micro SD's their hard to remove from the printer along with being easily lost. Is there a cord or adapter that goes from USB to Micro SD? Iv searched but only come up with USB>MicroSD
My thought was if there was an adapter that had a female USB to MicroSD I can just plug my standard SD>USB converter to transfer the slicer flies to the printer?
https://linustechtips.com/topic/1483529-usb-to-micro-sd-possible/
Something like this exists. Could put a normal SD card in it then just insert the end of this in the Micro SD card slot. https://www.tvc-mall.com/details/sd-card-socket-female-to-micro-sd-tf-male-memory-card-kit-extension-adapter-testing-tools-sku801100215a.html
Ryzen 7 7800x3D -  Asus RTX4090 TUF OC- Asrock X670E Taichi - 32GB DDR5-6000CL30 - SuperFlower 1000W - Fractal Torrent - Assassin IV - 42" LG C2 - Windows 11 Pro
That is 100% what I'm looking for with a flexible ribbon!! Thank you!
