Headphones not detected after each restart
ChopNorris
Hello everyone,
I've swaped my PC a few days ago and I'm having a problem with my headset. I have a Philips Fidelio X2HR connected on a DAC from aliexpress that was recommened by a friend (not sure if I can post the link, the model is DAC CS43131 DSD256). I had this setup working perfectly in my old PC, but after swaping to the new one I have to unplug and replug the DAC each time so It is detected.
After that it runs seamlessly, but It is pretty annoying to unplug it every time I turn on the PC. I'm connecting it directly to an USB C port on the back of the mobo, but I've also tried it in the other port and using the USB C to USB A that I was using in the old PC.
Edit: Forgot to mention that some times also happens when opening a game.
Any idea of what can it be?
Thanks in advance!
15 minutes ago, ChopNorris said:
Hello everyone,
Thanks in advance!
Try updating your Drivers if that doesn't work then try a BIOS update.
Have you tried turning it off and on again? Maybe Restart it?
Please make sure to Mark the Solution as a Solution.
Take everything I say with a grain of salt. I could be just about wrong as I am right.
Main RIG
13600K (Undervolted) +MSI Z690 Edge Wi-Fi+ Team Elite 32gb RAM (3200) +Noctua Nhd-15 Chromax Black+ Intel 670p 1TB SSD+ Intel Arc A770+ Corsair Crystal 465x case+ EVGA SuperNOVA 650W PSU.+ ASUS VP222 Gaming Monitor
Laptop for School: Surface go 2 (sucks ass)
Laptop for tinkering: Dell Inspirion 3358
Audio: Apple Airpods Pro (1st Gen)
(Apple_reigns_ supreme_ forever_ and_ ever)
(I am 15 years old and don't know shit about fucking shit.)
Everyone must suffer one of two Pains: The pain of Discipline or the pain of regret and disappointment.
-Jim Rohn
Did both just after building the PC, sadly I don't think that is the problem.
Thanks!
Thanks!
have you tried any Different ports?
Main RIG
-Jim Rohn
Yes, tried both the USB C ports and also with an adapter to USB A.
On your Old PC, would you plug it in to a USB 2.0 or 3.0?
Main RIG
-Jim Rohn
 I would say 3.0, but not completely sure.
I've noticed than it does it too when I turn on the xbox wireless controller. Not sure why it could be.
wireless interference
Main RIG
-Jim Rohn
The controller is connected via a usb receiver, and the dac and headphones are completely wired. How could it cause an interference?
Thanks again!
Thanks again!
There is wireless interference around you all the time. It depends on if the signals are running off of the same channel as anything else which could cause interference.
Main RIG
-Jim Rohn
