Budget (including currency): 2500-3000€
Country: Germany
Games, programs or workloads that it will be used for: God of War, Cyberpunk 2077, Horizon Zero Dawn, Elden Ring, Borderlands 3, Valorant, Webdev (maybe VMs for testing)
I have 2 1440p 144hz Monitors i usually play on and don't need anything besides the computer itself. I've tried to mix and match from some builds I've seen on here and on pcpartpicker but have barely any experience in building a computer, so I'd appreciate any recommendations. So this is what i came up with for now:
PCPartPicker Part List: https://de.pcpartpicker.com/list/8ZHnv3
CPU: Intel Core i7-13700KF 3.4 GHz 16-Core Processor  (€417.90 @ Alza)
CPU Cooler: be quiet! Dark Rock Pro 4 50.5 CFM CPU Cooler  (€88.20 @ notebooksbilliger.de)
Motherboard: *ASRock Z790 PG Lightning/D4 ATX LGA1700 Motherboard  (€230.93 @ Mindfactory)
Memory: *G.Skill Aegis 32 GB (2 x 16 GB) DDR4-3200 CL16 Memory  (€81.98 @ notebooksbilliger.de)
Storage: Kingston KC3000 1.024 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€89.90 @ Alza)
Storage: *Kingston KC3000 1.024 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€89.90 @ Alza)
Video Card: XFX Speedster MERC 310 Black Edition Radeon RX 7900 XTX 24 GB Video Card  (€1199.00 @ Mindfactory)
Case: NZXT H7 Flow ATX Mid Tower Case  (€133.88 @ Amazon Deutschland)
Power Supply: *NZXT C1000 (2022) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (€154.90 @ Amazon Deutschland)
Total: €2486.59
https://linustechtips.com/topic/1483406-first-build-advice/
I would go for this:
CPU: AMD Ryzen 7 7700X 4.5 GHz 8-Core Processor  (€365.99 @ Mindfactory)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler  (€63.90 @ Alza)
Motherboard: Gigabyte B650 GAMING X AX ATX AM5 Motherboard  (€223.05 @ Computeruniverse)
Memory: Kingston FURY Beast 32 GB (2 x 16 GB) DDR5-5600 CL36 Memory  (€148.42 @ Computeruniverse)
Storage: ADATA XPG GAMMIX S70 Blade 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€172.89 @ Computeruniverse)
Power Supply: NZXT C1000 (2022) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (€154.90 @ Amazon Deutschland)
Total: €2462.03
Generated by PCPartPicker 2023-01-24 08:24 CET+0100
https://linustechtips.com/topic/1483406-first-build-advice/#findComment-15765981
Here is a more premium build if youre into that kind of a thing.
Motherboard: Asus PRIME Z790-A WIFI ATX LGA1700 Motherboard  (€342.90 @ Amazon Deutschland)
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400 CL32 Memory  (€215.89 @ Alternate)
Storage: Crucial P5 Plus 2 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (€186.98 @ Computeruniverse)
Case: Fractal Design Torrent ATX Mid Tower Case  (€221.89 @ Alternate)
Power Supply: SeaSonic PRIME PX 1000 W 80+ Platinum Certified Fully Modular ATX Power Supply  (€306.99 @ notebooksbilliger.de)
Total: €2979.75
Generated by PCPartPicker 2023-01-24 08:28 CET+0100
OR
CPU: AMD Ryzen 9 7900X 4.7 GHz 12-Core Processor  (€447.99 @ Mindfactory)
CPU Cooler: ARCTIC Liquid Freezer II 360 56.3 CFM Liquid CPU Cooler  (€118.90 @ Alza)
Motherboard: Asus TUF GAMING X670E-PLUS WIFI ATX AM5 Motherboard  (€351.99 @ Computeruniverse)
Case: Corsair 5000D AIRFLOW ATX Mid Tower Case  (€187.20 @ Amazon Deutschland)
Power Supply: Corsair RM1000x (2021) 1000 W 80+ Gold Certified Fully Modular ATX Power Supply  (€213.89 @ notebooksbilliger.de)
Total: €2921.84
Generated by PCPartPicker 2023-01-24 08:32 CET+0100
To be an expert is to know more about less.
  • 2014 Build --> FX 8350 4.7GHz {} ASRock Fatal1ty 990FX Killer {} Reference GTX 980 4GB {} 2x4GB 1866MHz HyperX {} Seagate 2TB 7200rpm {} 840 EVO 120GB {} XFX PRO850W {} Noctua NH D14 {} Fractal Define R4 White Windowed
  • 2018 Build --> Ryzen 7 2700X {} ASRock Fatal1ty X470 Gaming K4 {} Gigabyte RTX 2070 8GB {} 2x8GB HX Fury 3200MHz {} Toshiba P300 2TB {} Kingston 480GB A1000 {} Corsair RM750W {} Enermax LIQMAX II 240 {} Fractal Focus G
  • 2021 Build --> Ryzen 9 5900X {} ASUS ROG Strix X570-F GAMING {} ASUS GeForce RTX 3080Ti ROG STRIX OC {} Gigabyte AORUS RGB DDR4 32GB {} Kingston KC2500 M.2 2280 NVMe 2TB {} Seasonic FOCUS GX-1000 {} ASUS ROG Ryujin 240 AIO {} NYXT H710i
  • 2026 Build --> Ryzen 9 9950X3D {} ASUS ROG CROSSHAIR X870E HERO {} ASUS GeForce RTX 5090 32GB ASTRAL LC {} G.Skill TridentZ Royal Neo RGB Silver DDR5 CL28 6000MHz 2x16GB {} Samsung SSD 4TB 9100 PRO M.2 {} Seasonic 1600W PRIME TX Noctua Edition {} Fractal Lumen S36 V2 RGB 360mm AIO {} Fractal Design North XL Charcoal
https://linustechtips.com/topic/1483406-first-build-advice/#findComment-15765987
I was surprised that in a 2500€ build only DDR4-3200 was included.
Can you explain where your focus was?
If it is only the GPU and the rest should roughly match (not bottleneck it), I think there are some possibilities to save money.
Do you want to run the SSDs in Raid?
edit: Your case has only 1 fan, right?
edit2: this made me so curios, that I configured it myself in mindfactory
Not cheaper, but I've put a super fast (overspent) boot drive and a regular SSD as storage in.
Personally, I would gor for another case, but that is just personal preferences...
I was able to put DDR5 plattform into your budget.
Alternatively, I think you get the same gaming performance with the 5800X3D if you prefer DDR4.
And it is all from one place, which saves delivery and is convinient. (I did the same in December, I think the few Euros more is worth it to have everything from Mindfactory and they are the cheapest most of the times anyway.)
2500EUR.pdf with5800X3D.pdf
https://linustechtips.com/topic/1483406-first-build-advice/#findComment-15766034
I'm unable to open those pdfs.
And yes I've overlooked the DDR5 as I'm fairly new/unfamiliar with computer hardware but it would make sense to go for DDR5 as its not much more expensive.
What could bottleneck the setup?
https://linustechtips.com/topic/1483406-first-build-advice/#findComment-15766544
Total: €2979.75
OR
Total: €2921.84
I like the 2nd build quite a bit, however I've never used any Liquid cooling so is there anything that i'd need to know before going that way?
Also something i forgot to mention in my post is that i really don't care about any rgb if there are some options to save some money.
https://linustechtips.com/topic/1483406-first-build-advice/#findComment-15766566
Strange, I try screenshots...
First picture is the common part, that is probably set with your choice of graphics card and if you really need an overpowered SSD, you could take the Samsung. For all normal scenarios you don't need it and the NV2 is enough.
And than 2 screenshots of two possible ways to complete the build.
All these setups will give you ultra high in 1440p. I think it is almost a waste of money if you don't use 4K. I think for high-end 1440p 1500€ would be enough.
https://linustechtips.com/topic/1483406-first-build-advice/#findComment-15767744
