Hi Im planning to buy a razer deathadder 2013 soon but i hate the green color as it does not match my scheme which is white, I've seen people mod their deathadders to change the leds to different colors but their isn't a clear tut on how to do it. From what I've seen do you just replace the 5mm leds fro both the scroll wheel and logo? Has anyone done this mod before on this mouse?
https://linustechtips.com/topic/148329-razer-deathadder-2013-modding/
there is a white Deathadder for ya, you dont need to mod it, however it is for a team called counter logic, so it does not have Razer logo on it. It does have white leds scroll whell and logo. If you still want Razer, there is also a white Taipan, it is not some special editon for any team, a mouse from Razer with legit Razer logo on it. Also white leds.
Edit: DA esport white scheme  http://www.razerzone.com/licensed-and-team-peripherals/counter-logic-gaming-razer-deathadder-e-sports-edition/
       Taipan white edition. http://www.razerzone.com/gaming-mice/razer-taipan?src=pgm.81594800&utm_source=Razer_Social_Media&utm_medium=smlink_US_launch&utm_campaign=razer_taipan#white
-Desktop: Asrock H81M-HDS R2.0, Pentium G3258 4.2 ghz OC, Palit GTX 750 ti StormX, Kingston HyperX Fury 1600 4gb, Seagate Baracuda
-Laptop: MSI GE620DX, i72670QM 2.2 Ghz, 8GB 1333mhz Ram, GT555M 2GB DDR3.
-Gaming peripherals: Razer Deathadder 2013, Superlux HD 681 Evo Razer Goliathus Control Medium sizeCm Storm Quickfire TK white edition.
I have opened up my DA before and if you'd like I can take another look on the inside if you want. I already removed the LED on the razer logo and it is extremely easy to get to but I haven't looked at the scroll wheel one.
"If you do not take your failures seriously you will continue to fail"
Ye thanks that would be very much appreciated. I'm an experience solderer so if its just a led soldered on the mother its fine. Could you take picture of it by any chance?
I have no camera unfortunately. However the LED for the back in connected by a wire/cable. It is not directly attached to the board so you might just be able to pluck it off and replace it. Now that you reminded me I can go pop mine open again.
Alright sounds pretty simple. What about the scroll wheel led? BTW which model do you have? 2013? But I doubt it'll have major changes to the LEDs because it really only an exterior and laser change.
I don't know where the scroll wheel LED is. I never removed it so it is most likely inside the wheel and plugged in through the side. Although I could not see the cable that connected it to the PCB.
False; both LEDs are soldered to two separate PCBs inside the mouse. The top half is attached to the top shell and the bottom half attached to the base; when you remove the mouse, be careful not to damage the ribbon connector (between the two daughter boards) because doing so will KO the mouse (it's very fragile at the lead ends). The scroll wheel LED is mounted on the PCB just below where the scroll wheel actually is, whereas the logo LED is mounted just behind the logo (I believe you can disconnect the logo LED for easier soldering; you cannot with the scroll wheel LED).
NOTE: the Deathadder uses a 5MM LED for the logo and a 3MM LED for the scroll wheel. I've only modded a 2012 Deathadder so I'm not sure if they updated it for the 2013 model, but you've been informed thusly.
Folding@Home | BOINC
CPU: AMD Ryzen 9 3900X + Celsius S36 GPU: ASUS TUF RTX3080
MB: ASRock x470 Taichi RAM: Corsair Vengeance RGB DDR4-2666 32GB
CASE: Fractal Design Define 7 Panda STORAGE: WD Black SN770 2TB + WD Red Pro 6TB
Alright thanks planning to buy the deathadder in a few days and awaiting my 5mm leds to arrive :D thanks big!
Please don't void your warranty by changing the LEDs. Deathadder is a mouse which sometimes needs warranty.
M.S.C.E. (M.Sc. Computer Engineering), IT specialist in a hospital, 32+ years of gaming, 20+ years of computer enthusiasm, Geek, Trekkie, anime fan
  • Peripherals: LG 32GK650F - Dell P2319h - Logitech G Pro X Superlight with Tiger Ice - Madlions MAD 68HE Pro - EndGame Gear MPC890 - Genius HF 1250B - Akliam PD4 - Sennheiser HD 560s - Tripowin Vivace - Simgot EM6L - Truthear Zero - QKZ x HBB - 7Hz Salnotes Zero - Logitech C270 - Behringer PS400 - BM700  - Colormunki Smile - Speedlink Torid - Jysk Stenderup - LG 24x External DVD writer - Konig smart card reader
  • Networking: Asus TUF Gaming AX6000 - Huawei OptiXstar EG8145X6-10 - 1000/500 Mbps fiber optic Internet access
  • TV and gadgets: TCL 50EP680 50" 4K LED + Sharp HT-SB100 75W RMS soundbar - Samsung Galaxy Tab A8 10.1" - OnePlus 13 16GB/512GB - OnePlus 9 256GB - Olymous Cameda C-160 - GameBoy Color - Miyoo A30 Spruce
  • Livingroom PC (dad uses): AMD FX 8300 - Arctic Freezer 64 - Asus M5A97 R2.0 Evo - 2x4 GB DDR3 1833 Kingston - MSI Radeon HD 7770 1GB OC - 120GB Adata SSD - 500W Fractal Design Essence - DVD-RW - Samsung SM 2253BW - Logitech G710+ - wireless vertical mouse - MS 2.0 speakers
Thats your opinion and most of the time I go along with it but sometimes are gotta do what you gotta do. :D In this case i really like the deathadder i had one a few years ago one of my complaints were that the sides we glossy and slips away from my fingers. Know other mouse fits my hands better but its green so I dont mind voiding the warranty.
