Hello everybody,
I will build a new pc and wanted some recommendations for good Airflow cases
Im gona put a 4080 in there with 1 HDD and 2 Nvme SSD the ssd isnt any problem
My choice rn would be the Pure base 500dx from Be quiet but if there are any better cases in that 100-110€ price range for better airflow please comment below
https://linustechtips.com/topic/1483169-case-recommendation/
I'm pretty happy with my Fractal Pop XL Air. 5900X w/PBO pushing 4.975 and an RTX3060ti-OC, peaks around 70-72C. GPU about the same.
I don't badmouth others' input, I'd appreciate others not badmouthing mine. *** More below ***
MODERATE TO SEVERE AUTISTIC, COMPLICATED WITH COVID FOG
Due to the above, I've likely revised posts <30 min old, and do not think as you do.
THINK BEFORE YOU REPLY!
https://linustechtips.com/topic/1483169-case-recommendation/#findComment-15763508
I like my Torrent Compact. On its own in stock config its pretty decent. Add some fans and its pretty wicked. When I am running my 5900X I have it boosting to 5150 with AGESA 1203. My power limits are 240/160/190 +200 -25 and she rips. I run WCG and F@H quite a bit, the case is great for that.
If you do happen to try my limits, be careful.. 240w PPT is pretty intense.
AMD R9 9900X | Thermalright FW Pro Black, 3x TL-B12E | Asus Strix X670E -F | 64GB G.Skill 6000C26
Zotac 4070 Ti Trinity OC | WD SN850, SN850X, 2x SN770 | Seasonic Vertex GX-1000 | ProArt PA602
Adcom GFP-345, Adcom GFA-555, S.M.S.L D1+PS100, Cerwin-Vega! CLSC-15, Monster HDP-1800
https://linustechtips.com/topic/1483169-case-recommendation/#findComment-15763739
