12700k for 350C$ or 12600k for 300C$?
Solved by Dedayog,
22 minutes ago, Dantel said:Im playing Rust and it is mostly cpu based game. I had 11400 and because of my trash dell motherboard I couldnt even get half performance out of my cpu. Now I decided to build something that will not make problem for games and if I wanted to stream one day then I can do it. I dont know how much difference between 12700k and 12600k. You guys know a lot about pc but Im just curious to know what is the difference. one of them i7 one of them i5
The 12700K is 5-10% faster than the 12600k. So not worth a 15-20% price bump, IMO. You may think otherwise.
Or you can simply Youtube the comparison on your own.
