First PC (help)
Solved by FI Fheonix,
Just now, imrllykool said:Budget (including currency): US$ 1500
Country: USA
Games, programs or workloads that it will be used for: Halo Infinite, Spider-man, MW2, CIV6, Minecraft
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I have 0 peripherals. I would like 1440p and 144 Hz but I can understand if it won't fit the budget. I have a Windows key. Would like wifi.
Working on my own part that goes above budget: https://pcpartpicker.com/list/BpNhXy. It may be more clear in what I am looking to do.
How about this? https://pcpartpicker.com/list/3yRPk9
