So I have a new build(Building one for myself and a friend). I have an issue of it shutting down. It was working fine for 2 weeks then one day it just shuts down. I thought a piece was was overheating, let it cool turned of PSU came back(everything cooled) started up after 30 mins shuts down. All drivers are up to date. I've swapped parts with the other PC and all parts are working. Thought it was the motherboard, other issues came up, exchanged it from an MSI MPG X670E Carbon to the ASUS Rog Strix X670E-E. Installed it in case worked fine then shut down after 30 to 45 mins of very light use. Took it out onto a test bench, works perfect, put back in the case won't start up. I am dumbfounded. Never after all my builds am I so confused. Only thing I can think of is the case is shorting out the board somehow but I see no issues with the contact spots to make this a thing.
Case: MSI 100R
Motherboarth: Asus Rog Strix X670E-E
CPU: AMD 7700X
CPU Cooler: Noctua NH-U12A
Ram: Teamgroup 2x16gb 6000hz CL30
PSU: Seasonic Focus 1000w Gold
GPU: EVGA 3090 FTW3 Ultra
Drives: 2 M.2 WD Black, 1x500GB 1x2TB, 1-HDD 720RPM 500GB(Been driving through all my comps)
https://linustechtips.com/topic/1480787-new-build-problem-solving-help/
Hm, I was gonna say the PSU but 1000W and from Seasonic I doubt it its the problem.
Try to unplug headers of the case from the mobo (This includes power button). Turn on the pc using START button on mobo and see what happens. Double check and re-seat 24pin connector, and 2x8pin connector of mobo.
To be an expert is to know more about less.
  • 2014 Build --> FX 8350 4.7GHz {} ASRock Fatal1ty 990FX Killer {} Reference GTX 980 4GB {} 2x4GB 1866MHz HyperX {} Seagate 2TB 7200rpm {} 840 EVO 120GB {} XFX PRO850W {} Noctua NH D14 {} Fractal Define R4 White Windowed
  • 2018 Build --> Ryzen 7 2700X {} ASRock Fatal1ty X470 Gaming K4 {} Gigabyte RTX 2070 8GB {} 2x8GB HX Fury 3200MHz {} Toshiba P300 2TB {} Kingston 480GB A1000 {} Corsair RM750W {} Enermax LIQMAX II 240 {} Fractal Focus G
  • 2021 Build --> Ryzen 9 5900X {} ASUS ROG Strix X570-F GAMING {} ASUS GeForce RTX 3080Ti ROG STRIX OC {} Gigabyte AORUS RGB DDR4 32GB {} Kingston KC2500 M.2 2280 NVMe 2TB {} Seasonic FOCUS GX-1000 {} ASUS ROG Ryujin 240 AIO {} NYXT H710i
  • 2026 Build --> Ryzen 9 9950X3D {} ASUS ROG CROSSHAIR X870E HERO {} ASUS GeForce RTX 5090 32GB ASTRAL LC {} G.Skill TridentZ Royal Neo RGB Silver DDR5 CL28 6000MHz 2x16GB {} Samsung SSD 4TB 9100 PRO M.2 {} Seasonic 1600W PRIME TX Noctua Edition {} Fractal Lumen S36 V2 RGB 360mm AIO {} Fractal Design North XL Charcoal
Okay, so update: I tried the suggestion, problem continues. I reinstalled Windows continue to have the problem. The problem is doing it in the case and on the test bench. So doesn't matter where anymore.
Remember I have two computer almost identical.
The following I have tried:
Swapped GPUs
Swapped PSUs
Swapped RAM
Swapped CPUs
Swapped M.2 Drives
Pulled Power Switch pins
Reinstalled Windows
The only differnces between the two now is the motherboard(use to be the same problem happened on both) and CPU Cooler(Comp A: Noctua NH-U12A/Comp B: Noctua NH-D15)
I do notice that if I run 3dMark or start any game it happens immediately or within 10-15 minutes of play. Windows Event Log also is no use(The previous system shutdown at 7:14:09 AM on ‎1/‎12/‎2023 was unexpected.) All the logs are non-descriptive.
Comp A:(currently on test bench)
Case: MSI 100R
CPU: AMD 7700X
Comp B:
Case: BE QUIET! 500DX
Motherboarth: MSI MPG X670E Carbon Wifi
CPU: AMD 7700X
CPU Cooler: Noctua NH-D15
GPU: EVGA 3090 FTW3
