Drive space issue
Solved by Needfuldoer,
I'm pretty sure Windows boot volumes can't be extended across multiple physical disks. If you had continuous unallocated space on Disk 1, you could add it to your C partition.
You can create a new folder on the B: drive and redirect your Downloads directory to it. That would keep the download mess off your C drive.
