Cpu debug light is on when i power on the computer. about 2 weeks ago, the build posted fine, but i never installed windows or anything. I have already tried reseating the cpu, clearing cmos, reseating GPU(multiple times) disconnecting unnecessary stuff, redoing power connections, and a few other things. Please Help!!!!
Msi b550 mpg gaming plus
ryzen 5 5600
rx 6600
https://linustechtips.com/topic/1479534-cpu-debug-light-on/
I am on my phone and msi website is a little hard to navigate on the phone. I would wager that you most likely need a bios update and that would solve your issues.
My PC Specs: (expand to view)
Main Gaming Machine
CPU:  Intel Core i7-14700K
CPU Cooler: Deepcool LT720
Motherboard: MSI PRO Z790-P WIFI
Memory: G.Skill Trident Z5 RGB 32 GB (2 x 16 GB) DDR5-6400
Storage 1: Samsung 990 Pro 2 TB
Storage 2: Crucial P3 Plus 4 TB
Video Card: EVGA XC3 ULTRA GAMING GeForce RTX 3080 10GB
Power Supply: Corsair RM850 850W
Case: Corsair 7000D Airflow
Case Fan 140mm: Noctua A14 PWM 82.5 CFM 140 mm (x7)
Monitor Main: MSI G274QPF-QD 27.0" 2560 x 1440 170 Hz
Monitor Vertical: Asus VA27EHE 27.0" 1920x1080 75 Hz
https://linustechtips.com/topic/1479534-cpu-debug-light-on/#findComment-15738955
i cant, my usb drive(128gb ) is too big fro the max bios flash usb(32gb) also, why would it not work now but worked before?
https://linustechtips.com/topic/1479534-cpu-debug-light-on/#findComment-15738958
Just now, Giannak said:
thx for the suggestion though
What was the computer doing before that it isn’t now? Typically newer hardware will require a bios update.
You can get a 16/32 gb flashdrive for extremely cheap. In fact on my Walmart app they have a 32gb sandisk flashdrive for 7 dollars in store.
Main Gaming Machine
https://linustechtips.com/topic/1479534-cpu-debug-light-on/#findComment-15738975
i put it into a case, and then it would not post. no new hardware.
https://linustechtips.com/topic/1479534-cpu-debug-light-on/#findComment-15738984
