Hi
I have installed steam os on a asus eeepc.
And it runs very slow for example when I move my mouse it wil move on the screen 2 secs later and very choppy thats why I didnt came further than setting the time zone and now it wont go further ,and the linux desktop acted normal
are this problems with steamos or is the hardware from the pc just to low end.
pc hardware:
  • cpu:Intel® Atom™ N550 (Dual Core; 1.5GHz) Processor
  • ram:DDR2, 1 x SO-DIMM, 1GB
  • storage:320GB HDD
  • os: windows 7 starter + steam os
any help is welcome
https://linustechtips.com/topic/147939-steamos-problems/
Hi
pc hardware:
  • storage:320GB HDD
any help is welcome
sorry mate it is just too old and weak to handle steam  os
CPU: Intel core i7-4770 --- CPU Cooler: Corsair H105 --- GPU: Asus Geforce GTX 970 Strix --- MB: Asus Maximus VI Hero --- RAM: Corsair Vengeance Pro 16GB
Case: Corsair Obsidian 750D --- PSU: Corsair AX860i --- SSD: Seagate 120GB --- HDD: Seagate 2TB + Toshiba 1TB --- ODD: Asus External DVD-R
Keyboard: Razer Blackwidow 2013 Ultimate --- Mouse: Logitech G602 --- Mousepad: Corsair Vengeance MM600 --- Monitor: LG 29UM65
https://linustechtips.com/topic/147939-steamos-problems/#findComment-1975782
I didnt know that steam os is any harder to run then normal linux
People overrate Linux's low resource footprint. Yeah you can get it to run on super low specs if you want to run a extremely stripped down version and/or with no GUI, but at that point you can just do the exact same thing with Windows anyway if you really wanted to.
CPU: i7 4790K  RAM: 32 GB 2400 MHz  Motherboard: Asus Z-97 Pro  GPU: GTX 770  SSD: 256 GB Samsung 850 Pro  OS: Windows 8.1 64-bit
https://linustechtips.com/topic/147939-steamos-problems/#findComment-1976355
