I have an Ender 3 Pro and have been loving it over the last few months but have a question regarding filaments.
My current stuff is PLA but I am wondering if I can do PETG and/or Nylon.
I have all stock parts but was wondering if I can print PETG stock or If I need to get a Bowden tube/upgraded hotend.
Does anyone know what the max temp a stock ender 3 pro can do? I find mixed answers online, and I know the PTFE tube is my current thermal limit.
Thanks!
| If someones post is helpful or solves your problem please mark it as a solution 🙂 |
I am a human that makes mistakes! If I'm wrong please correct me and tell me where I made the mistake. I try my best to be helpful.
System Specs
<Ryzen 5 3600 3.5-4.2Ghz> <Noctua NH-U12S chromax.Black> <ZOTAC RTX 2070 SUPER 8GB> <16gb 3200Mhz Crucial CL16> <DarkFlash DLM21 Mesh> <650w Corsair RMx 2018 80+ Gold> <Samsung 970 EVO 500gb NVMe> <WD blue 500gb SSD> <MSI MAG b550m Mortar> <5 Noctua P12 case fans>
Peripherals
<Lepow Portable Monitor + AOC 144hz 1080p monitor>
<Keymove Snowfox 61m>
<Razer Mini>
https://linustechtips.com/topic/1479352-ender-3-pro/
You should be able to print PETG no problem with stock parts on an Ender 3 pro, though you may have issues with bed adhesion. I suggest printing on a raft, but some suggest painters' tape or a glue stick (which I think are terrible solutions personally). Set your bed temperature to 60, initial layer height to 0.02 and nozzle temperature to about 230 (though you should just use whatever the filament you buy says to use).
https://linustechtips.com/topic/1479352-ender-3-pro/#findComment-15737559
Yes, you can print PETG just fine with the stock parts. I've never tried nylon, so I can't say anything about that unfortunately. As for the Ender 3 Pro's maximum temperature, I've gone up to 265C to print ABS and it performed reliably.
Computer engineering PhD student and RFML researcher
Daily Driver:
CPU: Ryzen 7 4800H | GPU: RTX 2060 | RAM: 32GB DDR4 3200MHz C16 | OS: Debian 13
Gaming PC:
CPU: Ryzen 5 5600X | GPU: EVGA RTX 2080Ti | RAM: 32GB DDR4 3200MHz C16 | OS: Windows 11
https://linustechtips.com/topic/1479352-ender-3-pro/#findComment-15738755
