Help with SFF Build in the LianLi x DAN A4-H2O
All of those builds would suit you well, however they are all using last-gen CPU platforms. Theres nothing wrong with that, but imo when you're spending 3k on a PC right now, you should be getting Intel 13th gen or AMD 7000 series. AMD Also just annouced their 7000X3D CPUs coming next month, so you may want to wait for those and see how they preform.
If I were you, I would take a look at the peformance differences between the two in your CAD and 3D modelling applications. As with gaming you're going to be hard-pressed to see the difference between the two in the real world. AMD Also just annouced their 7000X3D CPUs coming next month, so you may want to wait for those and see how they preform.
Its also worth noting, Intel 13th gen CPUs are on their 700 series motherboards, which will not have an upgrade path. So, if you care about having the option to upgrade your CPU down the line without needing a new motherboard, I would probably lean towards AMD. However, given you do profesional work, performance in those applications should be your first priority over upgrades down the line.
