Too much visible cables imo in both cases
option 3: route the cable from behind so it doesn't cover the GPU at all
https://linustechtips.com/topic/1479215-build-question/#findComment-15736667
I think that'd look neatest, but I have never cared about esthetics all that much.
I will recommend changing the fans on your radiator to a pull-configuration though, cleaning it will be more annoying if you leave them like this.
It is also recommended to mount the rad with the tubes facing down to avoid air getting into the pump, it seems like your tubing might just be long enough for it.
Trans Rights!
Please tag me or use the "reply" function so I get a notification
I will find your Laptop thread and I will recommend an ITX build instead
Sure would be neat if there was something useful here, eh?
https://linustechtips.com/topic/1479215-build-question/#findComment-15736674
You're right about tubes, but not sure they can fit in the bottom there isn't much space, and the rad can't be placed higher neither, case looks small...
https://linustechtips.com/topic/1479215-build-question/#findComment-15736681
Really? It seems like there's enough tubing, with it getting hidden behind the GPU and all. It's a question of whether it can fit through the hole in the shroud, but it should be a tad easier with the fans on the other side of the rad.
Trans Rights!
https://linustechtips.com/topic/1479215-build-question/#findComment-15737278
Yeah I meant space in the hole on the bottom, tube length should be ok
I won't put the front fans on the inside on pull, it looks worse from the front (you see the rad..) and is worse for airflow as well
https://linustechtips.com/topic/1479215-build-question/#findComment-15737299
It can't fit I tried and the tubes are to short
https://linustechtips.com/topic/1479215-build-question/#findComment-15738719
