It doesn't have a front USB3 header from what I can see.
The 990FX extreme 9 has two front panel USB3 headers, but is significantly more expensive and you may not like the metalic looking accents.
The Gigabyte GA-990FXA-UD5 has a similar colour scheme and a front USB3 header, but the header is located at the bottom of the board.
"PSU brands are meaningless, look up the OEM."
https://linustechtips.com/topic/147890-asrock-970-pro3/#findComment-1975248
