I made mistake installing on my usb Ventoy NTFS GPT and now I want to install there MBR version. Here comes my confusion. Since updating software to the latest version(1.0.86), when I try to install ventoy on usb, all I have is big pop up window prompting me to type "yes" in the box, to confirming that I want to do a fresh install instead of upgrade and that's it. After that nothing's happening. I've got only 2 buttons in program window - install and update. That's it.
Can you help me to make it work please. My usb doesn't have any phisical button preventing writing to it.
https://linustechtips.com/topic/1478430-ventoy-issues/
Most likely you need to type YES in capitals as it shows.
You can always open disk management / use diskpart / any other partitioning tool and delete all partitions on the drive if not.
F@H
GPD Win 2
https://linustechtips.com/topic/1478430-ventoy-issues/#findComment-15731629
HAHAHAHA it was soooo  simple 😄 😄 😄 Thank you. It worked
https://linustechtips.com/topic/1478430-ventoy-issues/#findComment-15731640
