javasript Javascript variable not being constant?
Solved by C2dan88,
This is because ${hash} is only set for when the image is added. ${hash} wont be set when the onclick event handler is triggered when you click the X.
You should use the event object passed to the onclick handler (e) to remove the parentElement instead
document.querySelector(`[close="a${hash}"]`).addEventListener('click',function(e) {
e.target.parentElement.remove() // remove the parent element for X button that was clicked
}, { once: true }) // remove the click event automatically once clicked
