Budget (including currency): 700 EURO
Country: Estonia
Games, programs or workloads that it will be used for: Rust, Steam
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): Samsung Odyssey G5
I need help checking if these parts work together and nothing goes booom. No need to worry about the money everything is already in budget.
Case: AeroCool CS-107
CPU:  Intel® Core™ i5-10400 Processor
Motherboard:  Asus PRIME H510M-E
Graphics:  ASUS GeForce® RTX 2060 DUAL OC / 6GB
SSD: Kingston NV2 PCIe 4.0 NVMe 250GB SSD - 3500/2800
RAM: KINGSTON FURY KF432C16BB/8 8GB/3200/CL16
Power:  Be quiet! System Power 9 CM 500W BN301
https://linustechtips.com/topic/1477417-need-help-with-planning-pc/
Country: Estonia
Should be fine however In your shoes I would invest a bit more for a higher wattage power supply and a 1TB ssd. If you really plan on using this PC for nothing but playing this one game than by All means go for it but if you factor in normal pc stuff, win 10, and potential other games? That 250gb are gone in no time at all, plus if you ever want to upgrade your gpu you will also need to upgrade your powersupply along with it. Because 500w are not much by todays standards…
Country: Estonia
Honeslty, for the money, you could do a bit better than that 2060 even used
I know Im due for an upgrade
asus Z10pe-D16ws
dual Xeon E5-2640 E4
128gb ddr 4 2400
2x GTX 1080 SLI
512gb m.2 boot
dual 2tb ssd
EVGA SuperNova 1200w P2
Phantek case
all Noctua Air Cooled
Thank you for help, I will look into that
