Need help
Solved by Somerandomtechyboi,
43 minutes ago, Darkharry said:It has safe boot, i think that i will expierence bottlenecks with RX 6600 and degrade it thats why im looking to take 1660 TI
That literally doesnt matter, youll have a faster gpu once you upgrade your cpu and if you go high resolution the cpu becomes less of a bottleneck, but with a crappy 1660ti you are stuck at the same performance
