CPU Fan Error!
3 hours ago, DoNotDropIt said:Ah thank you for posting the manual, I just looked it up myself aswell. I don't understand why Corsair wants me to plug the AIO cable into the standard CPU_FAN header, when there is an AIO header where I could plug it in. Should I switch it up, or do I just keep the CPU Fan header control deactivated in the BIOS? There wouldn't be any real benefits or?
Corsair AIO kinda "special" like I mentioned.
If I understand their "mindset" correctly :
The cable you plugged into AIO header is just a Tachometer cable, to measure pump rotation and such.
The power for the pump & fans comes from SATA, the report & command for the fans & pump comes from iCUE through USB2 & Commander Core.
AIO Pump header is usually a fan header but with more current treshold but without capability to increase/decrease speed (runs at full speed all the time).
[Refer to your motherboard manual]
https://forums.tomshardware.com/threads/corsair-icue-150-3-pin-pump-tach-cable-issue.3718568/
https://forum.corsair.com/forums/topic/159430-h115i-proone-lead-on-the-pump-tach-cable/
