Keyboard help
Solved by Bombastinator,
2 minutes ago, EdOrange said:Cheers, I’ll have a look over those. I was only looking for “entry level” I’ve only ever used membrane so don’t know any better.
Mostly they’re louder and less mushy and they’re so long lasting you can will them to your grandchildren. Oh and they usually light up, but you have to mess with the programming on the things if it distracts you (it does me)
