Welcome to the forums.
For anybody to be able to recommend anything, we need to know your budget (and country/currency) and what you want to do with the PC.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
https://linustechtips.com/topic/1476495-need-help-with-a-pc/#findComment-15718806
3 minutes ago, James coombs said:
I already have a ATX case that supports all atx and I have a key Boared and mouse and monitor I just need some new components I can upgrade over time I can start with Inter grated graphics
 Budget is £300-£400
https://linustechtips.com/topic/1476495-need-help-with-a-pc/#findComment-15718807
12 hours ago, James coombs said:
beaming, mine craft etc and upgrading it overtime
Then you should get something with a APU and then you can upgrade to a Gpu like 6600 when you have the money. it cost 342.73 euro
PCPartPicker Part List: https://pcpartpicker.com/list/QF7RbK
CPU: AMD Ryzen 5 5600G 3.9 GHz 6-Core Processor  ($105.73 @ Amazon)
Motherboard: Gigabyte B550M DS3H Micro ATX AM4 Motherboard  ($128.69 @ MemoryC)
Memory: *TEAMGROUP Vulcan Z 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory  ($46.99 @ Amazon)
Storage: *Silicon Power P34A60 512 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($28.99 @ Amazon)
Power Supply: *Thermaltake Smart BM2 550 W 80+ Bronze Certified Semi-modular ATX Power Supply  ($54.99 @ Newegg)
Total: $365.39
Generated by PCPartPicker 2022-12-27 03:22 EST-0500
https://linustechtips.com/topic/1476495-need-help-with-a-pc/#findComment-15720121
PCPartPicker Part List: https://pcpartpicker.com/list/RYcY78
Motherboard: *ASRock B550M-HDV Micro ATX AM4 Motherboard  ($100.44 @ Amazon)
Case: Cooler Master MasterBox Q300L MicroATX Mini Tower Case  ($69.98 @ Amazon)
Total: $407.12
Generated by PCPartPicker 2022-12-27 03:08 EST-0500
If op is willing to get a used gpu  he can probably save a bit by going to offer up or facebook marketplace
CPU: AMD Ryzen 5 5600 3.5 GHz 6-Core Processor  ($134.89 @ B&H)
Motherboard: Asus PRIME A520M-A II/CSM Micro ATX AM4 Motherboard  ($78.98 @ Amazon)
Memory: Silicon Power XPOWER Turbine 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  ($39.97 @ Amazon)
Storage: Silicon Power P34A60 512 GB M.2-2280 PCIe 3.0 X4 NVME Solid State Drive  ($28.99 @ Amazon)
Power Supply: Deepcool DA500 500 W 80+ Bronze Certified ATX Power Supply  ($45.99 @ Newegg)
Custom: RX 580 8GB ($100.00)
Total: $428.82
Generated by PCPartPicker 2022-12-27 03:19 EST-0500
https://linustechtips.com/topic/1476495-need-help-with-a-pc/#findComment-15720127
