Activating D.O.C.P: When I turn PC on, it shut down and immediately restart after
18 hours ago, 191x7 said:HWInfo64 shows 2 of my RAMs ticks having Kingston RAM which is impossible, the same as that Passmark tool. An it doesn't say which RAM, just the manufacturer.
Thaiphoon Burner shows the real data.
I'm also going to bed. Half past 4 here. XD
LOL i contacted Corsair, here's the response: (I attached the serial numbers of the two kits)
CORSAIR Support (Corsair)
26 déc. 2022, 13:27 UTC−8
Hi,
You are using two kits in your system, unfortunately this is not a supported configuration and you would only be able to use 1 kit (2 sticks) at the advertised speed. If you want to use all 4 sticks you will need to have XMP disabled.
BAM in my face. I guess it was that easy? Sad.
Fortunately for what i'm using the PC, ram speed does not matter.
I guess this is the solution
