help deciding on gpu
Solved by Gokul_P,
1 minute ago, xreaperx40 said:i was thinking of doing that as it is an option,i just really hate spending that kind of money on 1 part lol i guess these are the times were in lol....but i do want that limited edition 7900xtx so maybe thats an excuse to spend idk..i heard the 7900xtx was basically on par with the 4080 except for ray tracing which isnt a deal breaker for me so.
You are already spending alot and upgrade cost more when you need it. so if you have the money now go for the best one than after 6 months you want more power you have to spend almost double or triple what you now add to get a new gpu (you can realistically sell the old one but the value will be depreciated. Getting awesome Limited editions is a nice way to make your setup unique.
