If you have an extra USB header on the motherboard, you can use a controller like this.
https://www.amazon.com/Cooler-Master-Controller-3-Pin-Ports/dp/B07Z7WLWD5
Then use CM's software to control the colors.
Project Hot Box
Oppbevaring
Why is the 5800x so hot?
https://linustechtips.com/topic/1475708-argb-header/#findComment-15713421
