Budget (including currency): $2200 CDN
Country: Canada
Games, programs or workloads that it will be used for: Doom Eternal, CS:GO, RDR2, GTA5
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): I have a 1000W PSU and an ATX case I’ll be using for this build already. Not part of the above budget.
Hey All,
I have put together a couple build that I’d like to get some feedback on. One an Intel and the other an AMD. I’m looking to get a system for max setting 1440p together. Anything I should change for spending my money elsewhere?
https://ca.pcpartpicker.com/user/ToofySpooder/saved/cmnWcf
https://ca.pcpartpicker.com/list/KYdCnt
https://linustechtips.com/topic/1475641-couple-build-options/
Z790 board in general are just terrible value, especially for a 12th gen CPU.
Anyway, I swapped the board to a good Z690 board, then go with 13600kf and 16Gb 3600mhz.
32GB is still overkill for gaming.
https://ca.pcpartpicker.com/list/ppcctn
CPU: Intel Core i5-13600KF 3.5 GHz 14-Core Processor ($379.00 @ Canada Computers)
CPU Cooler: Deepcool AK620 68.99 CFM CPU Cooler ($75.79 @ Vuugo)
Motherboard: MSI PRO Z690-A WIFI DDR4 ATX LGA1700 Motherboard ($244.99 @ Amazon Canada)
Memory: TEAMGROUP Vulcan Z 16 GB (2 x 8 GB) DDR4-3600 CL18 Memory ($49.99 @ Canada Computers)
Video Card: Zotac GAMING Trinity OC GeForce RTX 3080 10GB LHR 10 GB Video Card ($1269.00 @ Amazon Canada)
Total: $2018.77
Or get 6950XT, which is much faster and cheaper.
https://ca.pcpartpicker.com/list/LGCy2m
Video Card: PowerColor Red Devil OC Radeon RX 6950 XT 16 GB Video Card ($1168.83 @ Amazon Canada)
Total: $1918.60
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1475641-couple-build-options/#findComment-15712827
Total: $2018.77
Total: $1918.60
Are you recommending the Intel build with the 6950XT?
https://linustechtips.com/topic/1475641-couple-build-options/#findComment-15713779
Yes.
But I didn't see that the other build was a 7600X, because it was private.
Regardless, I'd go with 13600KF because it ended up cheaper anyway.
https://linustechtips.com/topic/1475641-couple-build-options/#findComment-15713790
13 minutes ago, Dukesilver27- said:
Yes.
The reason I was thinking the AMD route was strictly for future upgrades. Maybe go to an X3D in a couple years?
https://linustechtips.com/topic/1475641-couple-build-options/#findComment-15713800
Well that's good too, I thought it would've been for like a long term build, should've mentioned that.
I'd change the the RAM to 6000 at least, frequency is everything for DDR5. And 6000 is the sweet spot according to AMD.
https://ca.pcpartpicker.com/list/V9q3Q6
CPU: AMD Ryzen 5 7600X 4.7 GHz 6-Core Processor  ($329.00 @ Canada Computers)
Motherboard: Gigabyte B650M AORUS ELITE AX Micro ATX AM5 Motherboard  ($274.99 @ Canada Computers)
Memory: G.Skill Ripjaws S5 32 GB (2 x 16 GB) DDR5-6000 CL36 Memory  ($227.88 @ Amazon Canada)
Total: $2076.49
https://linustechtips.com/topic/1475641-couple-build-options/#findComment-15713807
