6 minutes ago, fhrhnbbb said:
I have a pc built but my budget is 500$ and I need to bring it under. What should I do?
My video card I want to keep as a 1660 but I need to get it cheaper and the motherboard and cpu I want to keep the same
https://pcpartpicker.com/user/owudhuhaow/saved/gVpqHx
You say you want a 1660 but your build list has a 1650.
Single channel 2400mt/s RAM is going to absolutely kneecap your performance.
You could look at switching to an A520 board to save yourself $30 or so.
You would be better off to find a used GPU for around a hundred dollars. A secondhand RX 580 will beat the 1650 in most stuff and cost less.
Alternatively, if you are weary of buying any secondhand parts, I can only recommend building around a 5600G or 5700G APU and adding a graphics card later.
Corps aren't your friends. "Bottleneck calculators" are BS. Only suckers buy based on brand. It's your PC, do what makes you happy.  If your build meets your needs, you don't need anyone else to "rate" it for you. And talking about being part of a "master race" is cringe. Watch this space for further truths people need to hear.
hard to get it cheaper maybe used. used case is not a compromise at the cost of saving moeny.
Edited by thrasher_565
