Budget: 600$ US
Country: U.S.A
Games, programs or workloads that it will be used for: Minecraft, Forza, Call of Duty
Other details: This build is pretty close to final just looking for any tips that could improve on it and if things like the motherboard, case and psu are adequate for this build.
https://pcpartpicker.com/list/4F2ZC6
https://linustechtips.com/topic/1474777-my-first-pc-build/
Good
Cannot make it better for the price
https://linustechtips.com/topic/1474777-my-first-pc-build/#findComment-15707242
46 minutes ago, DicedDingus said:
Budget: 600$ US
Country: U.S.A
if you can add roughly $70, go with the 6600xt instead. it will be a better value than the 6600 at not much more cost.
https://linustechtips.com/topic/1474777-my-first-pc-build/#findComment-15707281
