2 Corsair sp120 quiet edition's
then you are golden. only way to reduce the temps is larger radiator or deeper
static pressure low speed fans. tbh, i'd reduce the voltage closer to 1.250v and
match with suitable multiplier. not really a performance hit, but the temps will be
more comfortable.
https://linustechtips.com/topic/147445-h100i-temps/#findComment-1969567
