DSOUND.dll problem
Go to solution Solved by Vishera,
2 hours ago, AxS said:
So, I've recently got an issue where image.png.c6cf434f9478813bc78a3667873bfcf6.pngthis keeps popping up every time I try to launch a game, and I have no idea how to fix it, anyone that can help
Maybe your dsound DLL is corrupt,
Here is mine + Total Virus scan:
32-Bit:
dsound.dll
https://www.virustotal.com/gui/file/474e728fd60122160bd9441bce9d88ab6835d63471dd2d928b24f00b6176e453
64-Bit:
dsound.dll
https://www.virustotal.com/gui/file/4f79690d02d0eddfdaa55cf54134b2f15cc2d465642103650726509891c486d0
32-Bit:
dsound.dll
64-Bit:
dsound.dll
A PC Enthusiast since 2011
AMD Ryzen 7 5700X@4.65GHz | GIGABYTE RTX 3080 GAMING OC | 4x 8GB Micron Rev.E (D9VPP) 3800MHz 16-19-14-21-58
https://linustechtips.com/topic/1474399-dsounddll-problem/#findComment-15705154
