Fan setup and GPU power cables
Go to solution Solved by Shooterdude34,
52 minutes ago, IchDie said:
Budget (including currency): everything bought already
Country: germany
Games, programs or workloads that it will be used for: gaming
Would it harm the power cables or reduce the lifetime if I were to plug the GPU in from above instead of below and have the cables semi-resting on the gpu backplate? (merc 310 speedster 7900 xtx black)
Should I set my 360mm top mount AIO fans to pull into the case or push air out of the case (Lian Li Lancool 216)?
for the gpu cables, it should be fine to have them route over the top of the card. although i would try to have them not touch the backplate. I have mine run over the top and pulled so that they help with gpu sag.
for the aio, if youre putting it at the top of the case I would have them push air out of the case, with your front fans pulling into the case. this would help keeping the flow similar to natural convection so that your fans arent having to fight the flow
Country: germany
Specs:
CPU: Ryzen R9 7900X  GPU: XFX Speedster Merc 310 7900 XTX Black  Motherboard: ASUS ROG STRIX x670E-F Gaming WIFI  RAM: G.Skill Z5 Neo CL 36 DDR5 6000  PSU: Corsair RM1000X  Case: Lian Li Lancool 216 CPU Cooler: Arctic Liquid Freezer II 360mm ARGB
https://linustechtips.com/topic/1474336-fan-setup-and-gpu-power-cables/
Country: germany
Country: germany
Cables touching the backplate are fine, it's not hot enough to bother the sleeving.  Sure it's hot to touch but cable sleeves can handle much more.
Top mounted AIO is usually push exhaust.  In front and bottom, out at top and back is the standard.  Obviously it can depend on case or whatever you want to do.
Onyx: Ryzen 7 7800X3D / Gigabyte B650 AORUS Pro AX / ASRock Taichi 7900xtx OC / G. Skill Flare X5 6000CL36 64GB (4x16GB) / Samsung 980 1TB x3 / Super Flower Leadex V Plat Pro 1000 / EK-AIO 360 Basic w/ Silent Wings fans / Fractal Design North XL (black mesh) / LG - UltraGear 45" OLED QHD 240Hz / Mackie CR5BT / SteelSeries Arctis Nova Pro / Cherry MX Board 3.0 / Logitech G502 - https://valid.x86.fr/my9nnr
7800X3D - PBO +200, CO -30 all cores, 4.90GHz all core, 5.05GHz single core, Cinebench 23: 18401 multi, 1779 single
Khaleesi: Ryzen 5 5600X3D (+200, -30) - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200CL16 - Asus Prime 9060XT 16GB - Samsung 980 1TB + Crucial MX500 1TB - Cudy AX3000 PCIe Wifi 6 - EVGA SuperNOVA 650 P2 - Thermalright Frozen Notte RGB 360 White V2 - NZXT H6 Flow RGB White - LG 34" 3440x1440
NAS/Plex/Game Server  Ryzen 9 5900XT 16c/32t - Gigabyte B550M AORUS Elite AX - TeamGroup T-Force Vulcan 64GB 3200CL16 - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + TeamGroup MP44L 2TB (Game) + WD Red Plus 4TBx2 (Plex) - TP-Link AC1200 PCIe Wifi - EVGA SuperNOVA 650 P2 - Thermalright Peerless Assassin 120SE - ASUS Prime AP201 - Currently Hosting: Enshrouded x2, Hytale, Icarus, Windrose, Project Zomboid, Dune Awakening.
Sage: Ryzen 7 7800X3D (+200, -30) - Gigabyte B650 Gaming X V2 - ASRock Steel Legend 7900GRE - G. Skill Flare X5 32GB 6000CL32 - TeamGroup MP44L 2TB - Super Flower Leadex Platinum SE 1000w - NZXT H5 Elite
Emma: i9 9900K @5.2Ghz - Gigabyte Z370 AORUS Gaming 5 - MSI 6900XT Gaming X Trio - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - Super Flower Combat FG 850w - Thermaltake Water 3.0 Ultimate 360 - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Extra parts: ASUS 6650XT - Gigabyte 1080Ti - Cooler Master Q300L - Gigabyte 450w PSU - Super Flower Leadex V Plat Pro 850w
OnePlus Ecosystem:
OnePlus 11 5G - 16GB RAM, 256GB NAND, Eternal Green. OnePlus Watch 2 - Radiant Steel, OnePlus Buds Pro 2 - Eternal Green
3D Printing:
Bambu Lab X1 Carbon, AMS, AMS2 Pro (thank you MicroCenter!)
Other Interesting Tech:
- 2021 Volvo S60 Recharge T8 PHEV Polestar Engineered - 415hp/495tq 2.0L 4cyl. turbocharged, supercharged and electrified.
