3 minutes ago, Kosmolol said:
So I have a pulsar 650w psu, and I want to get a gtx 1070ti, would it work with the psu?
Depending on which 1070 ti. You have to check if your power supply has the right amount of pcie cables. If you could send the psu model I could check for you.
https://linustechtips.com/topic/1474320-help/#findComment-15704310
