Budget (including currency): £800~900
Country: United kingdom
Games, programs or workloads that it will be used for: high refresh rate (144/165 hz )AAA gaming on 1080p with a possible upgrade to 1440p in the future and some light game development in unity and unreal
https://uk.pcpartpicker.com/list/fWmWLs
This is what I have, its fairly refined but I need some help with upgradeability and performance hits I have had to take due to my strict budget like:
the 12100f is just a budget place holder for a while so Will this motherboard be good enough to support CPU upgrades in the future to maybe a 12600kf or even a 13600kf?
Will the 3200mhz be much worse than 3600mhz cl16 ram?
And which of the gpu should I get for price to performance in general?
Thnks for the help 🙂
https://linustechtips.com/topic/1474050-my-first-build/
https://uk.pcpartpicker.com/list/sCt43y
Intel CPUs are not very sensitive to DDR4 speeds, so 3200 is perfectly fine. The 6650 XT was the best value of the 3 you selected, and will pair nicely with the 12400. The new motherboard is among the best B660s for its VRMs, so a 13600K in the future should work barring you keep its power in check. Speaking of power, I upgraded you to a more sufficient unit for those future upgrades.
the pc guy
https://linustechtips.com/topic/1474050-my-first-build/#findComment-15702367
https://uk.pcpartpicker.com/list/xKfk3y
¯\_ (ツ) _/¯
Went with amd since with intel you go straight for a 13600k combo or you are wasting money on crap thats gonna get outdated, still a viable route to get a weaker 12th gen and upgrade to 13600k if you do it within a year before next gen. You can close the performance gap between the 5500 and 5600 by just ocing to 4.6-4.8g 1.25-1.35v and clocking the balls off the rams but that may be abit board limited since cezanne goes to 5000mhz ddr4 in 1:1 fclk and the klevv 3600 bin has decent bin hynix djrs which id expect to do around 5200 with a max voltage of 1.7v (safe but not advisable to go higher cause imc nay degrade slightly)
Buy the 6800 used they float around 400£ on ebay
If youd like a better psu also look for a used one, pretty sure you can get a used actually decent 850w gold unit for the same price as this new bronze unit
https://linustechtips.com/topic/1474050-my-first-build/#findComment-15702498
12400 don't really need an aftermarket cooler, just the stock one.
Great B660 board for the price, should be able to handle 13600K.
16GB 3200 RAM. Solid value gen 4 SSD.
RX 6700 XT and 650W high quality PSU.
https://uk.pcpartpicker.com/list/dbWPd9
CPU: Intel Core i5-12400F 2.5 GHz 6-Core Processor  (£162.49 @ NeoComputers)
Motherboard: MSI PRO B660M-A DDR4 Micro ATX LGA1700 Motherboard  (£139.99 @ Amazon UK)
Memory: Patriot Viper Steel 16 GB (2 x 8 GB) DDR4-3200 CL16 Memory  (£46.50 @ Ebuyer)
Storage: Kingston NV2 1 TB M.2-2280 PCIe 4.0 X4 NVME Solid State Drive  (£52.36 @ Box Limited)
Video Card: MSI MECH 2X OC Radeon RX 6700 XT 12 GB Video Card  (£370.79 @ Newegg UK)
Case: KOLINK OBSERVATORY LITE MESH RGB ATX Mid Tower Case  (£52.44 @ CCL Computers)
Power Supply: NZXT C650 (2022) 650 W 80+ Gold Certified Fully Modular ATX Power Supply  (£77.28 @ CCL Computers)
Total: £901.85
Occassionaly visits the forum when I have nothing to do at work.
https://linustechtips.com/topic/1474050-my-first-build/#findComment-15702521
