My first time building pc
Go to solution Solved by that_potato_guy,
Personality I would've gone for the non f version cuz the integrated graphics can be useful and I think the ddr4 version of msi b660m a has better vrms than asrock's
Budget (including currency): $1600/IDR 25.000.000
Country: indonesia
Games, programs or workloads that it will be used for: Minecraft, Cities Skyline, Apex Legend, Premier Pro, After Effects, Davinci Resolve, Photoshop, Unreal Engine 5
Other details (existing parts lists, whether any peripherals are needed, what you're upgrading from, when you're going to buy, what resolution and refresh rate you want to play at, etc): This is my first time I'm building a PC, for peripherals i need mouse, keyboard and monitor that doesn't break often like 3 years and the keyboard has to be TKL or full size 60 fps 1080p is fine for me but i need monitor that have decent color and vesa mount compatible for audio i have headphone
I'm going to buy the GPU first in few weeks and then the rest of the components in 4 months, here is my PC that i want to build: https://pcpartpicker.com/list/Vr4q8r
Let me know if you have suggestions
Edit: The PCPartPicker don't have the case i was looking for, the case i want to buy is Lian Li lancool 205 mesh and i don't care about RGB
https://linustechtips.com/topic/1473344-my-first-time-building-pc/
https://pcpartpicker.com/list/FyXvQ6
The CPU cooler and PSU you chose were functionally fine, I just found better value options. Paying a little extra for 2TB of pure SSD could save you a headache down the road with a HDD since longevity is one of your concerns.
the pc guy
Good choice for the power supply but unfortunately in my country is not available
