LTT bit cross compatibility
Go to solution Solved by Whutdahell,
i have not received mine yet, but the hex shape is industry standard so it will go into another screwdriver, but your issue lies in the length of the bit as the megapro 24 in 1 drivers are double sided so this will not work for your situation.  and double sided bits aside, other drivers hold more of the bit than the ltt driver so you may have issues removing ltt bits from non ltt screwdrivers.
hello, new to the forum and im not exactly sure how to navigate it yet so im sorry if this is the wrong place for this, but are the screwdriver bits that you can order separately from the screwdriver compatible with the megapro 24-in-1 precision screwdriver? just looking for a cheaper screwdriver that also has magnetic tips and dont really know much about screwdrivers, i just saw the project farm video that said the megapro screwdriver was pretty good for its low cost, sorry if this is a dumb question, thanks.
https://linustechtips.com/topic/1473221-ltt-bit-cross-compatibility/
Problem is, the Megapro Precision driver uses double-ended bits while the LTT Screwdriver uses 20mm long single-ended bits. The LTT bits (and all other standard bits, for that matter) will just slide into the shaft of the Megapro driver without stopping.
