ARGB header
Go to solution Solved by Poinkachu,
12 minutes ago, Ailema said:
This is more complicated than I thought.
I bought a pack of 3 fans.
  • Cooler Master Sickleflow 120 ARGB 3-1 pack
Now, I can only manage their color if I connect a female of one of the 3 fans into the ADD_GEN 2 header on the motherboard (which seems to be the right one for ARGB - 5v).
While I can connect their lights, they do not power up... I mean, isn't supposed that if they are connected to the ADD_GEN 2 header, they have power to '' spin '' ?
- So it seems that the solution is, make the connection above mentioned and use a PWM 3 to 1 splitter to connect it to a CHA_FAN2 header on the motherboard in order for them to work.
- Is this the right method?
Yes, that is the right method.
4pin PWM / 3pin cable to Fan Header on motherboard / hub
RGB/ARGB cable to RGB/ARGB header on motherboard / hub
The wiring for each (RGB/ARGB and Fan Motor) are separate inside the fan.
RGB and ARGB headers are solely to light up the leds.
Fan headers are solely to power and/or control the fan's motor.
https://linustechtips.com/topic/1473155-argb-header/
Refresh before you reply
https://linustechtips.com/topic/1473155-argb-header/#findComment-15695832
