What case
alan93
what one of these two cases would be best for cooling? corsair 7000D airflow or the Lian Li O11DXL-X O11 Dynamic XL ROG Certified (Black) ATX Full Tower Gaming Computer Case? If i go with first one what is a decent fan hub to get. the mother board i'm using doesn't have enough fan headers but it will for the second one if i'm correct. if it helps, the cooler is rog strix lc II argb. The motherboard is MSI MPG Z690 CARBON WIFI DDR5 LGA 1700 Intel Z690 SATA 6Gb/s ATX Intel.
If you don’t already have the cooler, it’s not a good cooler and it’s from a somewhat reprehensible OEM- it’s Asetek-made. Don’t buy it, instead buy a better, cheaper cooler like the liquid freezer II. Otherwise don’t bother swapping, its good enough to use.
The 7000D Airflow probably has better cooling since instead of a tempered glass front panel it’s a nice mesh airflow panel. But it shouldn’t be that different.
What are you trying to cool?
It's not just about getting the biggest case you can, it's about controlling the proper flow of air thru a case.  Even a small midtower can outcool those 2 if you don't think about proper fan placement.
Onyx AMD Ryzen 7 7800x3d / MSI 6900xt Gaming X Trio / Gigabyte B650 AORUS Pro AX / G. Skill Flare X5 6000CL36 32GB / Samsung 980 1TB x3 / Super Flower Leadex V Platinum Pro 850 / EK-AIO 360 Basic / Fractal Design North XL (black mesh) / AOC AGON 35" 3440x1440 100Hz / Mackie CR5BT / Corsair Virtuoso SE / Cherry MX Board 3.0 / Logitech G502
7800X3D - PBO -30 all cores, 4.90GHz all core, 5.05GHz single core, 18286 C23 multi, 1779 C23 single
Emma : i9 9900K @5.1Ghz - Gigabyte AORUS 1080Ti - Gigabyte AORUS Z370 Gaming 5 - G. Skill Ripjaws V 32GB 3200CL16 - 750 EVO 512GB + 2x 860 EVO 1TB (RAID0) - EVGA SuperNova 650 P2 - Thermaltake Water 3.0 Ultimate 360mm - Fractal Design Define R6 - TP-Link AC1900 PCIe Wifi
Raven: AMD Ryzen 5 5600x3d - ASRock B550M Pro4 - G. Skill Ripjaws V 16GB 3200Mhz - XFX Radeon RX6650XT - Samsung 980 1TB + Crucial MX500 1TB - TP-Link AC600 USB Wifi - Gigabyte GP-P450B PSU -  Cooler Master MasterBox Q300L -  Samsung 27" 1080p
Plex : AMD Ryzen 5 5600 - Gigabyte B550M AORUS Elite AX - G. Skill Ripjaws V 16GB 2400Mhz - MSI 1050Ti 4GB - Crucial P3 Plus 500GB + WD Red NAS 4TBx2 - TP-Link AC1200 PCIe Wifi - EVGA SuperNova 650 P2 - ASUS Prime AP201 - Spectre 24" 1080p
Steam Deck 512GB OLED
OnePlus:
Other Tech:
- Ubiquiti Amplifi HD mesh wifi
the case and aio last things i need to get so the aio isn't set in stone put i did see that the case can support 480mm aio's so any suggestions? The CPU is a 13900k if that helps
the gpu is a 3090ti and cpu is a 13900k
i suggest the Arctic Liquid Freezer II in 420mm if it fits! They also make an a-rgb one.
ya i just seen one for like $160 on newegg and didn't realize that the case has a fan controller thing so that should be enough then with the motherboard. the case has support for a 420 on the front of case and on the side so it should work.is it better to go all 120's or 140's. it's either 12 120's or 7 140's. minus where ever the aio is.
Doesn’t matter that much but i like to use the biggest fan the case supports- so if it supports 140s use em and you won’t need to buy as many fans. I suggest arctic’s p14 pwm pst 5-packs. again, they come in rgb too- same fans used on the liquid freezer series
not super big on if rbg or not really. just care about performance.
Fractal Torrent
