there is something wrong with the fans on my card, but i don't want to send it back for rma, because i don't want to wait for however long without a graphics card. i noticed that the aftermarket white edition fans are 4.5amp, and the black ones are 5.0amp.
is there a difference with that 0.5amp? because i have a black card, but i bought the white fans, and i get strange noise from the fan bearing between 1500rpm and 1800 rpm. i don't know if that's something to do with the ampage.
thanks.
https://linustechtips.com/topic/1471635-asus-gpu-replacement-fan/
0.5 amps shouldnt matter too much, but isnt 5A a bit too high? That would be 60W for each fan, so 180W for the 3fans alone.
Interim 15 T200 OKF("F" intel processors are specifically archituctured for gaming) maybe upgrad to 13'900 | Peeralight cpu fan | Stryx Z690-A Wife(which is branded by ASUS and it's ROG label) | Thermotake 16x 8x2GO SODINM 2400mjz cl22 (2 of them with the mood lighting) | 980 EVO 1TB m.2 ssd card + Kensington 2TB SATA nvme + WD BLACK PRO ULTRA MAX 4TB GAMING DESTROYER HHD | Echa etc 3060 duel fan dissipator 12 GBi(It never overheats over 70°c) and Azrock with the radian 550 XT Tiachi | NEXT H510 Vit Klar Svart | Seasonice 600watts voeding(rated for 100.000 hours, running since 2010, ballpark estimate 8 hours a day which should make it good for 34 years) | Nocturna case fans | 0LED Duel moniter
New build in progress: Ryen™ 8 7700x3D with a copper pipe fan | Z60e-A | Kingstron RENEGATE 16x2 Go hyenix | Phantek 2 the thar mesh in front | lead lex black label psu + AsiaHorse białe/białe | 1080 Pro 8TB 15800MB/S NvMe(for gaming this increase fps and charging time, cooled by a M.2 slot with coolblock and additional thermopad) and faster 4000GB HHD | MAI GeForce GTX 2070 Ti Ventura 3x and RTX 6800 | Corshair psu
my card is still under warranty, but it's too much of a hassel to do the rma thingy. i could only find aftermarket fans. the ads for white fans say 4.5amp, and 5.0amp for black fans. i have a black card, but i got the white fans. the noise is very noticeable between 1500rpm and 1800rpm. everything is fine outside of that range.
so i thought maybe that missing 0.5amp made the fans more difficult to maintain within those rpm range.
please advise. thanks.
Can you post  link to the fans?
That's half Amp not five Amp. The 0.05A difference shouldn't make any difference.
weird why they would make the black and white fans different in ampage, and even in diameter and screw holes...
i tried to find specs for black and white cards, but nothing really specifies screw holes distance.
