I have recently moved and have had to buy a WIFI card for my PC as I cannot run an ethernet cable from the modem to my PC. My download speed is 100mbs.
When I test my internet speed via my phone or tablet on any speed testing site is get well above the 100mbs. But when I test the speed from my PC it maxed out at 12mbs for one site and well above 100mbs on others. Steam and Origin download games at around 10mbs. I am not sure what to trust when determining what speed my internet is for my PC. Does anyone know what could be causing the discrepancy?
https://linustechtips.com/topic/1470960-internet-speed-different-between-devices/
Distance to access point, line of sight and obstructions, quality and transmission power of both the card and access point... lots of variables can be causing this.
Main Rig:
Ryzen 5800x, ASUS Crosshair Hero VII Wi-Fi, 32gb of Corsair Vengence Pro SL 3600 CL18, Sapphire Pulse 9060xt 16gb, Noctua NH-D15 LTT Edition, Soundblaster AE-7, Beyerdynamic DT 990 Edition 600 Ohm headphones, 1tb ADATA SX8200 NVME SSD, 1tb Intel 665P NVME SSD, 500gb Samsung 850 EVO SATA SSD, 8tb WB Black SATA HDD, 14tb WD Ultrastar HC530, LG SATA Blue Ray Drive, EVGA 1300w G+ PSU, Coolermaster Stryker case, ROG ARGB strips, China ARGB fans.
HTPC:
Ryzen 5800xt, ASUS B550M Prime Plus WiFi II, 32GB of Corsair LPX 3200 CL16, ASUS 5060 8gb LP, Noctua L9-x65 cooler, WD Black SN770 500gb NVME SSD, WD Black SN770 1tb NVME SSD, Crucial MX500 2tb SATA SSD, WD Blue 2tb SATA HDD, Pioneer Blu-Ray burner, Intel AX200 WiFi/Bluetooth, Seasonic 300w TFX PSU, Silverstone ML11 case.
Retro Gamer PC:
VIA C3 1000Mhz, VIA Epia PD-10000 LVDS, 1gb of Kingston DDR, PNY Geforce FX5500 128mb PCI, WD 80GB HDD, Random CD-ROM, Random 250w mini psu, Mini ITX case 🤣
Just now, OU812 said:
Distance to router, LoS obstructions, quality and transmission power of both the card and access point... lots of variables can be causing this.
I put my phone and tablet in the same place as the wifi card when testing and they still get higher speeds than the PC.
There's a huge difference between MB/s (megabytes per second) and mbps (megabits per second). One megabyte is eight megabits. "mbs" isn't really an abbreviation of anything so I'm confused on what you mean.
Steam reports its download speeds in MB/s, and so 10MB/s would translate to about 80mbps, which is the measurement your ISP uses when measuring internet speed. That is normal. Origin does the same if memory serves.
Whatever test sites you are using, if they are anything other than the Google built-in test or speedtest.net, I wouldn't use it. Though really what matters and will be most accurate is your speed in the real world, and if it is actually 10MB/s in Steam, then that is perfectly normal if you pay for 100mbps.
A grumpy school IT guy with too many computers.
Primary:
Intel Core i9-10900K
48GB DDR4-3600 (2x16+2x8)
RTX 3060 12GB
a lot of SATA SSDs, too many some might say
Secondary:
Intel Core i7-4790K
16GB DDR3-1600
GTX 750 Ti
HTPC:
Intel Xeon e5-1620 v2
48GB ECC DDR3-1600
GT 730 1GB GDDR5
Laptop (ThinkPad W540)
Intel Core i7-4900MQ
32GB DDR3L-1600 (4x8)
Quadro K2100M
2880x1620 IPS Display
a glass trackpad stolen from an X1 Carbon G3
I have more... these are the ones that get used fairly often though.
9 minutes ago, |Hype| said:
Intel WIFI 6 AX200.
I should note that every speed test site shows speeds above 100mbs except one and downloading games.
a great many ISPs will detect when you are running a speed test and open the throttle to make it look like your connection is better than it actually is.
As to the slow DL under steam...I've seen where it starts slow and ramps up as more of the game is being downloaded.
Beyond that, troubleshooting wifi speeds is always a trick and you really can't compare with phones/tablets as that's not a 1-to-1 comp.
NOTE: I no longer frequent this site. If you really need help, PM/DM me and my e.mail will alert me.
Whatever test sites you are using, if they are anything other than the Google built-in test or speedtest.net, I wouldn't use it. Though really what matters is your speed in the real world, and if it is actually 10MB/s in Steam, then that is perfectly normal if you pay for 100mbps.
Sorry for the incorrect terms lol I am not knowledgeable when it comes to internet speeds and terms.
The built in Google test is showing 10mbps on my PC but +100mbps on my phone or tablet even when they are all next to each other. Speedtest.net shows +100mbps on my PC and phone. I am just confused about the difference between them.
The Steam and Origin download makes sense, thank you for explaining that. 🙂
