capture card looking for a capture card for nintendo switch
Solved by manikyath,
HD60 should be fine, the switch cant output anything beyond 1080p either way.
having that said.. gaming trough a capture card isnt ideal, usually there's at least a few frames of latency in the chain (the card needs to receive the frame, whatever software needs to grab said frame, send it to your GPU, and your GPU needs to output that frame.)
it really depends what sort of games you're playing, and how much you mind the latency.
