Front fan front radiator configuration
bricks33
Hello all,
I am eyeballing this micro atx build, and i have discovered the case I have chosen doesn’t support top radiators, only fans (haha). So could I place a 240 mm aio on the inside of the front where it is supported with front fans on my case? Or would I be creating a redundant airflow, now allowing air to cool the inside or the radiator? I would also add 240 mm fans on the top. Or perhaps could I face the fans on the aio to the inside of the pc? Allowing the front fans to cool the radiator, and the aio fans to cool the pc?image.thumb.jpg.9ba56f17b2c72a0ec7916c2b72043392.jpg
What case?
