[SOLVED] Black screen and fans speed up when under load
SOLVED
This fixed it for ME. This might or might not work you so keep that in mind:
Tip: Having another GPU to change out the problematic one helped a lot because It let me do things instead of crashing my computer every 3 minutes while I'm trying to fix it, but if you don't have one, hope it can get into safe mode (you need to for the DDU).
I did 2 things, but I don't know which one fixed it so try both just to be sure. I downloaded a DDU (display driver uninstaller) and uninstalled all my NVIDA driver (the problematic GPU) and then I turned off my pc, plugged in the NVIDIA one back in and downloaded all the drivers again and that seemed to fix it. Another thing I did was a updated all my drivers for my motherboard (Chipset, LAN, etc...) and that might of also fixed it.
Hope this helped and thank you to @191x7 for all the help.
