Aio liquid temps
Go to solution Solved by Skiiwee29,
Just now, Ebony Falcon said:
My ambient is 25c, at what point should I worry about liquid temps ?
if it gets above 50c is when you should worry. Above 50c is when you will have more evaporation and loss of fluid over its lifetime.
100% fine.
Community Standards
"Beast Mode"
Dedicated Streaming Rig
https://linustechtips.com/topic/1469160-aio-liquid-temps/#findComment-15667076
Community Standards
"Beast Mode"
https://linustechtips.com/topic/1469160-aio-liquid-temps/#findComment-15667080
Cranked my fans a bit and it come down to 36
-14900kf
- 4000 32gb ram
-4070ti super duper
https://linustechtips.com/topic/1469160-aio-liquid-temps/#findComment-15667085
