Right, so i ordered an NZXT 100cm LED Light kit, it has a molex connector on it with a red and a black wire.
When i came to plugging it in, I realised that my PSU only had molex 3 pin plugs, and the red wire on the Lights connector was in the 'bay' that the cable was missing from, ie, a 4 pin connector with 3 wires in...
What do you suggest i do, and can it harm my PSU if i switch the wires around in the lights molex connector? Then which wires would I match up? Ill take a picture so it's easier.
post-52255-0-31723200-1398973821_thumb.j
See. the black goes to brown and the red goes to nothing... surely the red is + and black is -?
AMD Ryzen 7 9800X3D ASUS ROG Strix B650E-F RTX 5080 Founders Edition  Corsair 32GB 6000MHz CL30 Corsair RM1000x Fractal Design North
https://linustechtips.com/topic/146853-corsair-modular-psu-problems/
the red is 5V. the 12V,which the LEDs need is yellow,so its all good why do you want to mix up the cables? the red is missing because its not needed
or did i misunderstood?
 the black molex is from the leds ?
if so leds need 5V,which your psu molex doesn`t have . don`t put the yellow in the red slot,its 12V.
Edited by s3ns3
The wires in the black molex (LED) go:             In the clear one, (PSU)
---------                                                              Yellow
---------                                                              Black
Black        Brown
Red        ---------
These were joined and nothing was happening. So I changed it to this
Red        Yellow
Black                                                               Black
--------                                                             Brown
And now it seems to work, albeit dimmer than they are in YouTube videos.
