Cpu 8+4 pin connection on motherboard.
Solved by Skiiwee29,
Yes, the CPU 8 pins come as a 4+4 for this reason as not all motherboards are 8 pin, some low end boards are 4 pin. So if you have an extra one you can definitely just use a 4 pin from the 4+4 to plug into it.
Featured Topics
Korhaka ·
Posted in Networking0 -
David3110445 ·
Posted in Troubleshooting2 -
Mark Sideris ·
7
Tea-Sir ·
Posted in CPUs, Motherboards, and Memory2 -
NotDeem ·
Posted in Troubleshooting3 -
digitalscream ·
Posted in Graphics Cards0 -
